1983 300SD, 1986 560SEL, 1992 300D, 1995 E320 Wagon
The puddle lights on the front doors come on but the rear ones do. Tested power to the front ones and nothing. I know the door jamb switch works because it makes the center dome light goes off and on with the door just fine.
Any ideas of where to look? Would one broken wire on one inside the door panel maybe make the other side not work too?
04 odyssey (265k) 1995 E320 wagon (295k)
Could be the relay behind the cluster. I burnt it out grounding out puddle light by mistake replacing the bulb.
Even if the rear ones still work and the main dome light works?
Yes, my driver's door puddle light does not work, and driver's door will not turn interior lights on. All other three doors it does.
