1 - 16 of 16 Posts
1995 s320
Hi all, I have been looking and searching but have not found anything on removal and replacing of the rear axle's.
Today just a block from home I accelerated and BOOM!! I hear this loud bang and then my car won't move.
Towed it home and put it on jack stands and the left rear half axle is loose and so forth.....wondering if I tore it up (broken)......Could be the Differential too I suppose.....First I thought Tranny.
If so anyone have a photo's or sequence on r/r this item, and how to do it....
I could just rip into it but I'm sure there is a smarter way and a 1,2,3..... method to it.
Anyone with this knowledge would be appreciated. Thanks,
Mitch. Merry Christmas right :(:(
2011 GLK,2007 S550,2003 S55,2008 CLK,2009 C300,1996 E300,2005 E320,2002 E3
Ill see if my indie took pics like he said..Just got my 91 SEC out of the shop for the same repair. That is a loud BANG.
S280 ,another s280,turbo 500 SEL bountyhunter beachbuggy,59 ford pop,vito
Just had the same bang from under my car earlier in the week and found one of the drive/half shafts had snapped near the wheel end just beside where the raised bit on the shaft is by the end of the joint boot(the break was hidden inside the boot which made me think the diff had gone initially)
Getting the shaft involves taking the nut (30mm i think) off in the centre of the hub and at the other end is 6 multipoint bolts ,easy as pie
1995 s320
Yea thanks to both of you on a quick response.
Yes I think it is near the wheel also on mine.......yea should be an easy fix I see PartsGeek does not offer the half shaft so I'll have to shop around....
probably looks like the inner cv joint should replace if I'm going to all this trouble to replace the shaft........I'll take a look when I'm in there though......Thanks again
Mitch
1995 s320
Holy Cow.....I have looked everywhere for this axle assembly and can't find anyone who has one........It's like all the years but this one.......
Does anyone have any idea's as to where to purchase a left rear axle assembly for a 1995 S320. Wow this is quite discerning obout this......
1995 s320
Well maybe someone will read this.....
Will a 1995 E320 rear axle assembly fit my 1995 S320 ???
I am Quite frustrated about the lack of a rear axle assembly listed for a 1196 S320. So I am hoping that I am just ignorant and the 1995 E320 fits the 1995 S320, But I will not buy this unit until I am told they are interchangeable.
Wow I need help on this....
I thought the shafts were all the same but some have the abs cutouts on and some dont (could be wrong though )
1995 s320
You know Trike I'm not sure either I hope someone in the know will let me know if the Axle assembly for the 1995 E320 and the 1995 S320 are interchangeable. That would help out alot...... PartsGeek.com has those for like less than $100.00 that would be sweet.........
Mitch
It's one on eBay right now at $139.00 buy it now....type Mercedes half axle in the search bar.
I have to help a fellow Ohio guy out..LOL
I just grabbed a similar part off Ebay last month/
95 Mercedes Benz S320 SWB
Are there any warning signs before an axle shaft goes on theres days? Im having some vibration from the right rear of my car and Im not sure what it would be.
1997 S600 (sold)
If it's the actual shaft that snaps, then no. That will just go boom without warning. If it's the CV joints wearing out, they may give some warning by clunking under load or when turning.
Vibration from the corners is almost always a wheel balance issue.
Brett
1995 s320
Discussion Starter #15
Hey Eddie would be for a 1995 S320 if so I just may have to take you up on that.....of course that is a used one yes?.......and do you know if the those shafts are interchangeable between the E320 and the S320. 1995 years...??
Mitch
Brett
Thats what im hoping for, tire might be out of wack it clears up at higher mph but at lower say 40mph there is a pronounced vibration from that right rear side.
1 - 16 of 16 Posts
