1 - 8 of 8 Posts
E350 Sport
both remotes work, locking/unlocking the trunk and passenger door but not drivers door.
i've tried the procedure in the om of aiming/clicking at the door and within 80 secs turn key to position 2 but it still doesn't work.
where to start looking.:cool:
tia
· Banned
Y2K SL500 Silver
tia
I believe your system is Infrared and you are trying this in bright daylight. Try doing the same thing in a garage area that does not have direct sunlight. If it still not does not work you may need to replace the door sensor.
· Banned
Y2K SL500 Silver
E350 Sport
1995 SL 500 2017 AMG GLC 43
Bearone2,
If you garage is like mine, I have it lit with enough fluorescent lights to double as an operating room, the IR remote will not function due to the interference from the lights. They are at or near the same wavelength as the IR signal. Don't go on a wild goose chase like I did when I first bought my 95SL thinking there was something wrong with the remote or the IR sensors. Once I searched for this issue on this forum my frustration stopped when I found the comments I discussed above. Read every post you can and you will quickly learn every little nuance of these vehicles. Good luck....
E350 Sport
Discussion Starter · #7 ·
Bearone2,
no flourescent lites. I'll keep looking and appreciate your comments.
at least the trunk and passenger door work with the remote.
thanks
· Banned
Y2K SL500 Silver
1 - 8 of 8 Posts
