1995 Mercedes Benz E 300 special edition,1996 mercedes E300 diesel
HI I HAVE A 1995 E 300 DIESEL AND I'M GOING TO BUY THE EXTRA ENGINE AND I FOUND ONE BUT IS DIFERENT .CAN SOME ONE TELL ME WHAT YEAR IS IT THE BLOCK NR ARE AM 6060110401 AND THE INTAKE IS 606141 066 . AND I'M WONDER IF THIS IS FOR NEWER
Cruise Control
'87 300TD Myna 7mm pump and HX30 /'89 Vanagon TDI 12mm pump and GT2052
I honestly don't know the answer to your question, but the short answer is that you should be able to run the long block for a naturally aspirated OM606 in any chassis requiring an NA engine. The long answer is, they aren't plug n' play between the two chassis, so there might be some swapping of parts in order to make it work. Here in the US, the OM606 NA was only available in the 124 chassis for the 1995 model year. The 210 chassis had a similar (though the injection system is different) OM606 NA engine from '96 till '97.
