1 - 10 of 10 Posts
1995 e320, 2002 ml320
Sorry if this is posted in the wrong section but I have a 95 e320 with no heat or ac. Checked all fuse panels with no result. The fuse before the main panel is also good.
Please help as the weather is getting colder and colder
thanks
nick
1993 230 TE.1999 om 606 td. and 722.6 3.2L,clk w208 1987 Kit car with 260e running gear.
Hi Nick,
The people on here that will be able to help you will need to know your location in profile.
Location makes a difference with your particular enquiry as car can be euro spec or other which elimanates or adds certain components.
Boyd:)
W124 Moderator
Nick,
When you say "no heat/no air" do you mean there is no air movement from the vents?
Jayare
No heat or air
Thanks for the reply
no air movement at all. Again at this point I am not if it's getting any power but fuses where checked
Thanks again
Could be bad blower motor regulator. You need to check for voltage at the regulator, assuming other components are OK such as the push button control unit.
W124 Moderator
Nick,
Was the lack of air movement a sudden failure? If so, check the strip fuse. It's just next to your hood alarm button. Remove the fuse to check it. They can develope hairline cracks and "look" good when they aren't. It is a 30 amp fuse and looks like the images below.
Jayare
Thanks,
I will check it again. The buttons work. When pressed , I can hear clicking noise from the dash ...but no air flow at all......
1994 E320
NNick..im in the exact same boat, will be installign new blower motor this weekend. Did you ever get resolution? was it the blower or the regulator?
W124
Jayare pointed out the most likely culprit, the fuse. The next likely cause is the regulator, followed by either the ignition switch or the blower itself. If its the blower it could be stuck, needing lubrication.
C320/300E/S500
2 Years ago I unstuck and lubed the blower. I thought I was going to have to do that again! Hurray, it was the fuse, it gets pretty warm on high speed and I guess it flexes, eventually cracks. good to go---
1 - 10 of 10 Posts
