While replacing the defective PSE vacuum pump under the back seat, the 21 pin connector casing separated. Does anyone have a picture or diagram of the 21 pin PSE pump connector which shows where the wires go by color? I have seen wiring diagrams of the system posted but need a picture or diagram of the connector itself which shows where each wire goes in the connector harness? Thanks.
1998 140.070 CL500, 1966 406.121 U65
While not exactly what you want, I think a combination of the posts in
this thread, will give you enough information. (combine the diagrams with
the numbering on the connector, and recheck with the pictures).
http://www.benzworld.org/forums/w140-s-class/1288970-picture-pse-please.html
I know that some of the links are broken, but thats related to explaining
other components * and not the PSE *.
I think you first should determine what diagram to look at. I * think *, its the last one.
Connector drawing should be the same.
br,
syljua
