Am getting this message after disconnecting the battery. I was hoping to get the CODE message (and I have the code to input into the system), but I cannot get beyond C-ERR whatever I do.
I have read threads saying this can be solved by both turning the key to position 1 (though I hate to do this for long - surely it will damage something?) while simultaneously leaving the radio turned ON for some length of time (up to 24 hours), which will then bring me to CODE.
Another thread I read says that the radio is now damaged and needs repair or replacement.
Seems strange that the radio would now become faulty just by disconnecting the battery...
Any suggestions/solutions/advice would be much appreciated. :)
W221 & Audio Moderator
2013 S550
The procedure you mention is recommended for some radios; I don't know enough about yours to be able to confirm it. You are not likely to damage anything - but I would shut down the air conditioning and anything you don't need to run - and you should charge your battery with an external charger while using the procedure. Be sure you follow your owner manual's charging instructions, so that you don't damage the battery.
Many thanks for this input, Skylaw. :thumbsup:
Does anyone else have any news on the success of this procedure - i.e. radio on and ignition set to position 1 for 24-hours - specifically for this radio (which came standard with my 1994 E-420)?
If there's something easier or proven, I'd love to know before attempting this.
I have attempted this remedy to the letter - and still nothing but the C-ERR message.
Does anyone have any suggestions? :surrender:
