Like Trevor said it is the Ignition Module, but along the way of the ignition module. The white thermal compound must be replaced, yet the old stuff must be cleaned-off entirely. The dried paste could be your problem
A medium to a large size tubes can purchased at electronic supply houses, or you could find them on FleaBay, but the ebay ones from China are too watery, and are prone to drying up rapidly. The stuff from the US never dries-up and it is thick...
The paste is never lathered on. The paste is there to promote thermal conductivity, and too much it works as a thermal isolator. The application of the paste should be on both surfaces, and it should look semi-transparent. It is there to fill the metal mating imperfections..
Get two to three tubes of this stuff:
New Aavid Thermalcote 249 Thermal Joint Compound CPU Heat Sink Paste 28g 1oz | eBay
Martin
