87' 190E 16V / 93' 600SL / 02' G500
Looking for info on the lug bolts on our 93' 600SL are they 12mm or 14mm? Also.. maybe one of you now's the length of bolt required to run the 17X8.5 and 17X10 Forged AMG 3 piece wheels made by OZ. I know those wheels are made for a 12mm bolt but not sure if the 600SL uses 14mm bolts like our 92' 600SEL. Dont want to order a set that would interfere with the rear e-brake. If one of you has a set in chrome that needs a good home.. Thanks in advance.
Discussion Starter #2 (Edited)
Well it turns out the 93' 600SL has 12mm bolts and the length or bolt required to mount these wheels is a shaft length of 40mm. Hope that info can help someone
