Show a video of the tachometer when you shift from neutral to drive or reverse. It sounds like your idle is too high but from under the car video sound can be deceiving.
I see you are flying the Canadian flag. in the USA, a 1993 300E or TE would have had the 3.2L HFM-SFI system shared with the 94-95 E320'sHello,
I am new to this thread. I own a 1993 300E ,,,
Is there any documentation on the Vacuum lines for the transmission? Unfortunately this car didnt come with an owners manual so I have been relying strictly on online resources.Low vacuum with cause hard shifts in all gears = check no vacuum lines have been damaged dislodged especially the one on the side of the box and its diaphragm.
Excessive clutch pack clearances will feel like a hard shift = rebuild the trans.
Poorly adjusted modulating pressure will cause hard shifts = adjust on the side of the box.
Too much throttle will cause hard shifts = adjust at throttle linkage in engine bay.
I will post a video when I get home, but essentially the condition I see is when I start the car up when its cool ; idles at ~600RPMShow a video of the tachometer when you shift from neutral to drive or reverse. It sounds like your idle is too high but from under the car video sound can be deceiving.
> Shift into D/N; RPMs spike to about 1100, it makes that clunk sound and the car jerks a little.
I have the M104 Variant with the 3.2L engine, I believe the Transmission code is the 722.369. and I did mean 150k KM, I apologize for my fat fingers LOL.I see you are flying the Canadian flag. in the USA, a 1993 300E or TE would have had the 3.2L HFM-SFI system shared with the 94-95 E320's
previous years 300E / TE had the M103 SOHC 3.0L, but the US 300CE cars had a M104 DOHC 3.0L CIS-E setup. that was available in the rest of the world as a 300E-24 or TE-24
so which car and engine do you have? the Rest of the World also got more transmission options than the US ever saw.
Post a photo of your linkage.So, I was able to spend some more time looking at the throttle linkage... and correct me if I'm wrong but theres supposed to be 2 springs on here? I have 0. one looks like it broke off and the other is MIA, is it possible that this is the root cause of my issue?
He came back saying "it idles at 600", but no photos of tach to verify. But then he says he is missing return springs on the linkage. This is why I want to see photos.What reves is it ticking over at ...i saw that this question was asked before was there any answer . I recon its running over 1000rpm much to fast and i see no proof of that ,,,,but i bet thats the reason .
I think I only require #38, was able to verify that 44 is present.if you have ASR its more complicated. for non-ASR, here's the parts blowup, which yeah, doesn't quite show how its assembled. I see the two springs,
- #38 - A1049930410 SPRING BETWEEN SLOTTED GATE LEVER AND BEARING BRACKET
- #44 - A1039930010 SPRING BETWEEN BEARING BRACKET AND THROTTLE VALVE LEVER
Would you be able show me where this switch would be on the linkage?Also check out the small micro switch in the linkage ..the witch should be closed on a no running engine .
Reviving this thread cause I have a similar issue. Did you manage to find a cure for this?Would you be able show me where this switch would be on the linkage?
