My the right front passenger window did not roll all the way up. I pressed the window switch several times and it finally went up. I replaced the switch, but the window continued not to work. I checked the fuses (#8 I believe) and the fuse was blown. I replaced the fuse and tried again, but the fuse went again. There is obviously a short and I suspect it is the window motor in the door.
Any suggestions?
