I need advice or help locating my amplifier in my 1992 SL 500. Does anyone know where its located?
its under the passenger side front floor board....carefully pull the carpet back from the front foot area....it folds where the flat part ends......there should be a plate back there held in with a nut....undo the nut....remove.....make sure you know which one is the amp as i believe you can set off passenger air bag if you grab the wrong thing......
Moderator
you should have 2 amps, what speakers are you having trouble with?
The mid-high amp is in the front as described.
The lows amp is in the trunk however, at the left side, behind the carpet
