1 - 9 of 9 Posts
Hi every one . I have a super clean and well maintained 600sel ,1992
I was trying to figure out front suspension rattle at the low speeds .
Finally found it .
Right front ADS shock has this 1/4" free play between the compressed movement,
Like something inside has loosen down.
I was able find practically new front shocks from later model .
My original shock has a long wire attached to it that leads all the way under the hood .
New shocks have just a plug. I was able to identify the plug and got those.
So before I go and try to burn something I would like to ask if Mercedes had a updated harness for that reason .
92 style shock is not made anymore.
If I can buy a new harness from a dealer I will do it.
Thanks for any help .
This is correct. The older style front ADS part number is deactivated and the new shock absorbers do not have the wiring attached to them.
Also, I don't believe you can buy the harness separately. If the existing one is in good shape, you might be able to reuse it (or make a new one using it as a template - there are only 3 wires to it)
2648769
1 - 9 of 9 Posts
