1 - 20 of 27 Posts
Can anyone point me to directions or preferably a video on how to remove the fluid container (reservoir) and steering pump box for a 1992 500SL ?
I've found YouTube videos on other model Mercedes which don't help me.
I can't see where you unbolt the reservoir to get to the pump.
I even purchased the STAR Service Manual Library Model 129 which I can't seem to load on any of my computers.
I want to try to rebuild my leaking pump or buy a new one.
Any DIY help would be appreciated.
Phil
This one should be close to yours.
Pelican Technical Article - Mercedes-Benz W129 / R129 - Power Steering Pump Removal
If your is anything like mine there are 2 bolts on the backside. torx bits
Rumb,
Thanks for your help. That was EXACTLY what I needed.
WOW, illustrations and clear guidance. Couldn't ask for anymore than that.
I'm going to have to check out Pelican Parts for more Technical Articles.
I wonder if they have anything on rebuilding that pump.
I sent away for the seal kit and was going to wing it but if they have anything like this article, it would be a great help.
Thanks again
Phil
If you need any other assistance, I have the dealer oem repair manuals that cover
everything. Just an FYI. Have a great holiday weekend!
Kayrunner
Kayrunner,
Thanks for the response.
Do you have any procedural documentation written or video that shows how to rebuild the Vicker's type Power Steering pump on a 1990 through 1992 500SL ?
I've found older or newer but not exactly that pump.
Thanks in advance.
Phil
Rumb,
When you say there are 2 bolts torx bits on the backside where are you talking about.
the reason I ask is I followed the Pelican Parts procedure. I have everything off but I still can't get the pump loose.
I've tried to get something behind it to break it free but it seems like there's something else holding it on.
I really want to smack it with a pry bar and a hammer but thought I'd ask you about those 2 bolts first.
So, can you zero me n on the location of the torx bolts and what size they are.
Thanks in advance.
Phil
Phil,
There is a very good thread on the removal and replacement of the power steering pump - http://www.benzworld.org/forums/w140...-overhaul.html - suggest you check it out. I followed those instructions and had no problem at all with the job. I do have the necessary tools (didn't use air tools with all of the aluminum involved) it is not a bad job.
Add a quart of MB PS fluid, blue Loctite and some rags and you've got what you need.
Good luck..
I guess the problem is that I can't get the bracket that holds the pump and the reservoir off to get to the those bolts.
There is also one bolt on the front that holds the bracket t to the block. After you get the whole thing off then you remove the pump from the bracket.
Discussion Starter #13 (Edited)
I removed three 13mm bolts; (facing the pump) one on the bottom, one on the left and one at the top right that is actually a nut on a stud and then the 5.5mm hex at the top left under the reservoir. Did I miss one?
P.S. not the 4 that hold the pump together.
Update:
I found a picture of the bracket and it looks like I have all four bolts removed.
So, I guess I have to put some force behind it and break it free. I hope I don't break anything. Any suggestions?
Discussion Starter #16
I added this yesterday but I have know idea where it ended up.
I found a picture of the bracket and it looks like I have all the bolts removed. 4 bolts, one of which is a hex bolt.
Could it be that it's just stuck from 120k miles of heat and grease and grunge?
I guess I'm going to go in with a pry bar and other implements of destruction and hope for the best?
I'll let you know how it turns out.
And I thought getting this thing off was the easy part. I hope the seals on the pump don't give me this much trouble.
Phil,
Let me try the link to the W140 forum again - http://www.benzworld.org/forums/w140-s-class/1481425-photo-diy-steering-pump-overhaul.html. This has some good photos: the E12 torx bolt on the back side of the pump that can only be reached from underneath the car is one that you probably have left and that is the worst photo. The reinstall photo is a little better. I can tell you for sure that if you are not underneath the car, you can't see it. Once you have all the bolts out it will drop right off.
(while it is titled steering pump overhaul it has a good remove and replace how to)
Again good luck.
Discussion Starter #18
Boydm,
This time the link worked. I can see that this is a different pump though. Mine is from a 1992 500SL. I'll look for the E12 Torx bolt. Are you sure it will be there on the 92 model?
In any event, this link looks like it will come in handy when I get the pump off and go to replace the seal and o-rings.
I've been referring to the following link I received from a user named rumb that lists the removal process:
Check it out.
I go through every step but can't seem to get it to budge.
I does seem like there is still something holding it on.
I had the front of the pump off trying to follow this procedure. If I can't get the bracket off, the only thing left would be to take the top off again and replace the main seal. I really wanted to replace that little 3 inch piece of hose that goes to the reservoir though. Unfortunately,I can't do that unless I get the bracket off to get to 2 bolts on the back of the bracket.
Arrrrrrrgggggg!!!!!!!
Thanks and let e know if you come up with anything else. I'll let you know if I have any luck.
Phil
Discussion Starter #19
Kayrunner, or anybody,
Would you be able to get me the blow-out diagram of the Power Steering Pump, reservoir and bracket with all the bolts and fasteners for my 1992 Mercedes 500SL ? I believe from 1990 to 1992 would work.
I think they changed to the SL500 in 1993 which had a different reservoir and bracket.
It would be greatly appreciated.
Phil
Discussion Starter #20
I'm not sure how this posting split into two but somehow it did. So, I'm entering this post again in this side of the split?
The 90-92 bracket is attached below.
Phil
1 - 20 of 27 Posts
About this Discussion
6 Participants
Keithdm
Mercedes-Benz Forum
Full Forum Listing
