2015 C300W4; 2007 E350 W211; 1992 300SE W140
I have done some work on my vehicle, and still trying to get the vehicle steering correctly.
I have replaced the front and rear shocks. The steering feels much better, but still a little strange. When I corner, the inside wheel doesn't seem to dip down into the turn like it should. It also feels a little wobbly (the car rocks a little side to side) when going over uneven roads.
Should I be looking at Track rods? Steering damper? Drag link? Idler arm? Boots?
If I do the work myself, will I need an alignment?
1993 300SEL (Sold) 2007 X5
How are your swaybar links? If the wheel is moving with bumps in the road then you need to replace your steering damper.
1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
You need a mechanic who knows how to align your Mercedes. I had a shop do it and it felt exactly as you described. Then I found someone who knew how to do Mercedes and it felt back to normal. Caster and Camber could be off in the front.
I am still a little confused about what the problem might be. I would like to learn a little about how the front end steering works. Anyone know of a good resource for learning?
