FS: 1991 White 300SEL w126 2nd Owner
For Sale is my Father's 1991 300 SEL (300SEL LWB) with 181K
White Exterior with Grey Interior
VIN WDBCA25D7MA561358
Clean Title
CA Registration is up to date and good till MAR 2013
2nd Owner (however records will show title has changed to both our names).
CA Smog Certificate completed and passed on 07SEP12
Reason for selling is that he just upgraded to a 420SEL with 78K!
We have a stack of service records from the original owner, which I will write up the details when I get them.
Detail photos coming, however below are two quick phone shots.
Interior and exterior in great 8-9/10 condition for its age.
- Car Phone (no active line, but turns on and works)
- CD Changer (in Trunk) *not working any more
Below are some recent servces that have been done with receipts (unless noted):
180,054 Oil/Filter Change
177,792 Transmission Replaced near rear main seal, new rear main seal housing cover, transmission gasket
176,736 Replaced Exhaust system, rubber mounts
174,300 Replace EHA valves/Air Filter
173,955 O2 sensor, spark plugs, wire set, dist rotor, gap and gasket
17x,xxx Replaced New MB windshield (noted in logs, but no receipt found yet)
171,231 Replaced front brake pads & Sensor
171,020 Replaced fan clutch, replaced outer tie rod, center tie rod, V-belt, upper belt tensioner, wheel alignment
167440 Replace cat/air filter
160745 replaced alternator
(more later)
Only known functional issues are:
- Driver side speakers are not working (guessing it is the head unit)
- Passenger seat adjustment switch doesn't work intermittently
Please let me know if you have any questions in the meantime.
Asking $3500
Thank you.
Car is located in Davis, CA area.
