Soft top not working
When soft is closed I push the soft-top button forward and windows go down, the tonneau cover comes up, the soft top comes out about a quarter way and stops. It does not stop immediately it sort of stutters/pumps up, down, up, down quickly - and then stops. The button blinks when this happens. I can then pull the button and it goes back into place. I can manually move everything into place. When the soft top is connected to the front I pull the button and the tonneau cover opens, back of the soft top compresses but the front does nothing.
I have gotten all the cylinders rebuilt still nothing. I got a new pump. Nothing. Plenty of fluid. Fuses are fine. Battery is good. Roll bar works fine. The micro switch on the driver's side bow extension cylinder clicks when I manually put soft top up and down.
I can put the hard top on and lock it down with the button. When hard top or soft top is locked down is does not move. Also, shop guy said they didn't have tool to scan it.
No clue what to do at this point any guidance would be greatly appreciated.
