1991 350SD, 1985 500sel (sold) 1988 BMW 528e (2) 1990 Jaguar XJ6 (Dont buy one of these)
I am from Appleton, WI. I have a 1991 350SD in which I am converting over to run a 300 om603 motor in it. Many brand new parts available including: Crankshaft, Timing Chain Tensioner, fuel injectors, belt tensioner, belt spring, motor mounts. All other engine parts available but not new.
So heres the story. I was on a road trip on the highway when my crankshaft keyway snapped. I had the car towed 100 miles back to my house where i could work on it. I pulled the engine and pulled the crank. I had a used crankshaft from another 350 polished, cleaned and inspected by a crankshaft specialist with 40 years experience. When the motor was reassembled, it was blowing black smoke. i re-evaluated the timing of injection pump and re assembled. Same thing. So I then had the car towed 30 miles to a diesel mechanic in Green Bay. They proceeded to replace all the fuel injectors, advising me that one was leaking and they all were old so I should replace them all, fishy I know now. Upon inspection that mechanic found some anti-freeze in the combustion chamber on top of the #4 piston. So bad head gasket possibly a cracked head. I will have the head x-rayed for damage to see if it is salvageable considering a replacement is $2300.00. please contact me via email for parts. [email protected].
Discussion Starter #2
I Have many brand new parts: Timing Chain Tensioner, belt tensioner and shock, all 6 fuel injectors. Breather Tube from valve cover to air intake. Make offers. Need to Sell.
W126 300SDL, W140 S320, W211 E320 CDI
Are the six injectors all new? Have Monark nozzles? Do they fit a 300sdl 1987 OM603?
If so can you PM me a price?
Im not sure if the injectores have Monarch nozzles. A mechanic ordered and replaced them. If you could describe them I could remove an Injector to compare. Yes they are brand new. The engine hasnt run since they were installed. I think I have a bad head gasket, possible bad head. 75.00 a piece injector lines thrown in for free.
I am also looking to swap a OM603 3.0l in this car so the only one out of your request i am willing to part with are the throttle brackets and linkages
