1990 420 sel 213,800 replaced water pump and radiator; the timing chain good
I've got a leaking Differential. I'm not sure what the part number is for the replacement seal. And is this something I could do myself? It seems pretty straight forward. Jack up MB, drain Diff, Loosen axle shaft, tie axle up out of the way, open diff cover, remove retaining clip, pull out connection flange and shims (don't lose), remove seal, replace everything in the order removed and keep it clean. Refill Diff with 90W. Probably be about 250 if I took it to our local MB Indy.
Discussion Starter #2
Checked the fluid level, it was ok, running out after removing plug.
Considering drain and refill.
it's a 2.47 ratio.
Mercedes Benz w126 300se
i did it the same way to the input side as in attachments
:thumbsup::thumbsup::thumbsup:
