About three months ago i purchased a '90 560SEC for $2000, i knew it would have problems but it ran and could get me around town. I had the engine tuned to hopefully fix its rather rough idle, and that mechanic made it run so rich i got 1 mile per gallon then when i got it home it wouldn't start. After kind of tuning it myself it got it to another mechanic that my friend recommended and he tuned it back to functionality but it was still rough. Within the last month the idle got worth and it started to stall at any speed (sitting at a light, pulling into my driveway, and scariest of all at 80mph on the freeway). I took it to the mechanic and he said it was my fuel distributor and he replaced that. The idle was smoother and it didn't stall for a week. This week i took it back after two weeks of intermittent stalling and he couldn't figure out what could cause it. I have read or been told by friends that it could be the fuel filter is clogged, the fuel pump is giving out, the injectors are clogged, there is a wire loose somewhere, or it's a vacuum leak.
So i guess i'm just here to ask which is the most likely cause and where should i start. It is not a pretty engine right now and needs a lot replaced and reattached, but i need to hit the biggest problem first and fix the stalling.
Also i could never figure out what the tiny box in the last picture does, it has two vacuum lines attached and one is not attached to anything.
