1 - 1 of 1 Posts
Two questions: (1) when pull lever to activate washer what voltage reading should I have at the motor/pump - 12Volts?; and (2) can the 3 way check value stop water from pumpimg to the nozzels? Note: Nozzels are not clogged as can disconnect hose at the nozzels and blow water thru the nozzels, but if try to blow water thru hose (at water source) when disconnected from the motor the hose seems clogged, as no water reaches the nozzels.
Thanks Bob
1 - 1 of 1 Posts
