1 - 15 of 15 Posts
1990 300sl =1976 450sl = 1998 e320 = 1999 c230 k =1999 corvette conv = 1996 corvette coupe
my 1990 300sl is slow , when i give it gas it just not have any power - it is like it is not geting the fuel and also the transmission does not down shift into passing gear . i would appreciate any help i have never had a 300 sl but do have a 450sl -e320 -c230k-300sel--this 300sl is sick .please help . thanks sammy in knoxville tn
slow sl
soory to be dumb but i do not know what you talking about. thanks
Something is wrong and your car is trying to protect itself from serious damage by limiting the engine speed, and the transmission etc. Yes, our MB are that smart, while other cars would just shut itself down, ours let you 'limp' home with it.
You will need to have a diagnostic scan to find out what's wrong.
slow 300sl
will do . thank you
Outstanding Contributor
'03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
A U.S. 1990 300SL does not have a limp mode for either its throttle or transmission.
The first thing I would probably do is check the condition of the spark plugs and their spark gap. If the car has always lacked power since you owned it, then I would also check compression. Next I would check the fuel mixture by measuring the current to the fuel distributor EHA and also viewing the feedback signal from the oxygen sensor. You need a basic electronic multimeter to perform the measurements, and this article details the procedures: PeachPartsWiki: Mercedes-Benz Driveability.
I would also check your cats. I used to have a 600sl where the cats broke up and blocked the exhaust. The car had no power and would not downshift properly. I did a quick fix by getting the mechanic to cut open the cats and remove the insides then weld the boxes again. instant power but slightly noisier. obviously it's a temporary fix until my new exhaust arrived because the car will not pass emissions testing like that.
WOOOOO HOOOOOO! POST NUMBER 300 FOR ME :D
slow 300sl
thanks friends, i took the car to the have the cat checked but he man their just felt of the tail pipe and said it was running rich and told me he thought it was the ox s -he never checked the cat=== i will check the plugs and start from their = as far as the cat it gets hot and smells after a 20 mile trip . thanks again i need all the help i can get ... sammy in tn
Sl man
Sorry about the mis-information of limp mode as I did not see in your profile what year car you have. BobTerry is the expert for our cars, so if there are ANY conflicting advices, his is most likely the correct ones.
2000 Obsidian Black Metallic Mercedes SL 320 V6
sl man welcome aboard in our big and friendly international family. To help us help you in the best and quickest possible way you should fill your profile with your car year and location.
Good luck on your problem.
Cheers.
Discussion Starter #11
i will fill out the profile. thanks again
Cheers.
will do and thanks to everyone
Discussion Starter #13
slow 300sl
thanks friends, i changed the spark plugs and the car runs great , stillruns rich - will work on that problem later . again thanks sammy
95 SL500, K&N, NEOKEN Ported TB, Custom Intake, RENNtech Sport Exhaust, AMG I Monoblocks
Hi Sammy, regarding your 1990 SL320 running rich, most likely the O2 sensors need replacement.
Best Regards.
Discussion Starter #15
slow sl
i will ckeck them . again thanks alot.... sammy in tennessee
1 - 15 of 15 Posts
