· W124 Moderator
86 190E 2.3L 16V, 95 320TE 02 S500
Tone,
Use the search function on this forum for your problem. You will find numerous threads. Welcome to the forum and tell us about your car.
Good Luck,
Jayare
Need more info - key won't come out? Key won't turn? The first thing you can do is order a new tumbler, by taking your title to the dealer, should be under $100 and will be keyed to your car. You're going to need one in any case. Some people have actually hooked up electric sanders to the key to vibrate them. You can usually get it to work if you just keep playing with it. With the key out it's pretty easy to replace the tumbler. You'll need to make a specific tool for the job, which can be made from coat hanger.
W124
If the key just won't turn make sure you take the load off the steering wheel lock mechanism by moving the wheel slightly in the direction that it moves most. Then try pushing the lock and key in the direction of the engine compartment and jiggle it up and down while trying to return it to the full off position. If you get it out, spray dry graphite into the lock and move the key in and out a few times. The lock may start working again but you must immediately follow the suggestion above and order the new tumbler and key that is correct for your VIN. It should cost $80 -$100 at the dealer but it will be the right key for the car. Then you need to follow the instructions in the archives for removing the tumbler and installing the new one. If you are used to DIY work it shouldn't take more than 15 minutes once you make the simple tool you will need. DON'T WAIT TO REPLACE THE TUMBLER. CONSIDER YOURSELF LUCKY IF YOU GET THE LOCK MECHANISM TO WORK AGAIN - IT WILL BE ONLY FOR A SHORT WHILE. IF YOU HAVE TO DRILL/CHISEL THE OLD ASSEMBLY OUT, YOU ARE SCREWED.
