1999 E320 (140k), 1995 SL500 (72k)
At times with closed throttle and AC on, the idle goes up to maybe 1000 for one or two seconds as compressor cycles. This can be a concern when comming up to a stop. I also notice the economy gauge (vacuum gauge) shows max vac on Heat and Econ but 1/8 on Defrost and AC. Disconnected Y7 and no change. I also get a low flow of cool air from center vent in Defrost and Heat. Are these connected? Thanks.
W124 Moderator
You have a vacuum leak someplace in the system. Start checking every line and every rubber connection. Don't overlook the vacuum line cluster just behind your power brake booster.
Good Luck,
Jayare
