just bought a 1990 300ce. 145k miles. In really good shape - so i am hoping that my transmission issues are not related to internal parts/bands/clutches being worn out from abuse or high miles -- which the car shows no signs of either.
Checked the fluid and is full, looks fresh and does not smell burnt.
Here are my observations(im hoping some are related to a common faulty part, etc):
-No delay in engagement of R or D.. but it does lurch into gear, no clunking.
-shifter linkage is a little out of alignment(presumably bushings) - and apparently this can cause internal issues with the transmission as well as affecting shift timing/pressure/etc
- no slipping while in gear, but a"flare" in 3rd and 4th gear shifts - speed sensitive; light gas, light flare -- heavy gas, longer flare as the rpms rise faster with more gas.. k1 kit for 3rd flare? and is there a similar "$10 plug n play part/kit" for 4th gear flare? the 4th gear flare is less pronounces. no flare from 1st to 2nd gear.
-No kickdown in any gears(although i have not tried to floor the car from a stop) -- it does start in 1st gear if i pull the shifter down to "2" and back again.
I am going to take the car to a shop called Transmeister in Orange, CA. From what i can tell, they only do transmission work on MB's. DOes anyone happen to have experience with this shop?
Before taking it to the shop, i was hoping i could check out some basic things first, in case something obvious pops out at me that is an easy DIY. I also have a mobile mechanic that i trust that may be able to save me some money.. however, he is a BMW mechanic, and has no experience with MB's -- so if i have him come see the car i would have to give him instructions on looking/troubleshooting.
I searched a dozen or so "w124 flare" posts and found a decent amount of info, but nobody seemed to have ALL of my problems listed, lol -- so i guess i was hoping to get some basic advice on some DIY troubleshooting, starting with the easy stuff - i.e I wont be dropping the pan myself, etc. I also wanted to post ALL my issues to see if anyone would post "duuude, thats a shitload of transmission issues; better budget for a rebuild" <--- would seem like a "logical" reply to a typical "faulty transmission", but im hoping nobody will jump the gun with this same response unless they that quite sure ive described a toasted gearbox.
Thanks!!
Thanks!!
