Ok, I'm not a mechanic so if this seems at all strange as to how I word this please forgive me.
I have checked the fuel filter and no problems with pressure there. No problems with pressure at the carburetor, have checked connections and they all have gas goin through.
Have pulled wires off cap and am wondering if it's a timing issue, if so how do I turn the cap to adjust, I don't see how you can do it.'
Again, it turns but it doesn't want to start and keep running.
Help?
Are you getting spark?
Yes I am getting spark. changing spark plugs right now, they are quite worn...trying to figure out gap measurement if needed on Bosch Platinum plugs. Also removing cap and going to check rotor as well. ignition coil looks fine...work in progress.
