The most expensive part of the 2.6L W201 is the engine and drivetrain, so have that checke...
The most expensive part of the 2.6L W201 is the engine and drivetrain, so have that checked out by a good MB mechanic. Piston chamber compression should be verified, oil comsumption or oil in coolant checked for, ask when/if the timing chain tensioner was serviced or replaced, as well as the serpentine belt tensioner. Check to see that fluids, including the transmission oil and differential oil were changed regularly. Although the W201 is pretty rust resistant, the known problem areas are around the jack holes, the trunk under the carpet and the doors, at the inside lower edges (if the rubber seals fail, water accumlates low in the door).
