Greeting,
Wondering if anyone could shed some light on a problem:
I got a 1989 MB 560SEL about 150,000miles. I was driving home, suddenly the car stalled in the middle of the traffic. When tried to restart the call (in both park and neutral), the engine turns over, but failed to start again. The instrument cluster has no power: all the instrument needle remained flat when the key turned. The fuel tank is half, and jumping the battery didn't help.
Does anyone have any idea what I should do next?
98SL500 89SEL560
I have the same car year and everything. Both the stall problem and the dead instruments happened. The stall turned out to be a clogged up fuel accumulator - cheap fix. The dead instruments are even easier to fix. Just clean up the contacts on your fuse box - or replace one if its burnt. Cheers.
