Can anybody help me?
Iwant replace the fuel pump relay but I have found a grEat number of part numbers suposed to fit this car.
I need help to know exactly which is the part number I must search?
My car is a 1989 300E, 124, VIN WDBEA30D0KA864548,
Motor 103 983 121 38047 E 9.2
86 300e Anke
Have you tried removing the one you have and see if the number is still on it?
It SHOULD be the first TALL RECTANGLUAR box on the RIGHT side behind the cover behind the battery...
:D
number illegible
Yes I did, but the number is illelible.........
I can say only, it is a nine pins ........
Thank you very much
IIRC, model year 1989 300E had fuel pump relay with p/n#0025455205 installed at the factory during production. This relay has 9 pins.
This part has been updated/superseded with p/n#0035452405. This relay has 10 pins but should work without issues, assuming the old relay was indeed the problem.
Only use genuine MB relays. Don't bother with knock-offs such as those from URO and other less reputable brands.
86 300e Anke
You can get one at Pep Boys... around $90...
It DOES have the extra pin, but the socket is not wired for it... think it is a redundant 'relay is engaged' signal or somesuch....
Please read 'Foreshadowing of things to come' about MY relay saga! Might help you ensure it IS the relay!
:thumbsup:
2006 C350 & 1990 300E
90 Bucks!! No way!! I know I paid cheaper from either rmeuropean or autohausaz. Can't remember offhand. Try those 2 sites for a fuel pump relay. As stated earlier, don't use Uro parts. Try Kaehler. I have a 90 300E.
86 300e Anke
Considering the dealer wanted $325 for a new one...
I was happy! :bowdown:
