Hello, perhaps some of you know this. What controlls the air pump to cycle on and off. Mine turns on for a half second when the car is fully warmed up
(80+) and I get a check engine light flash(no code) and the stumble I've been chasing for awhile. Can happen 5 times in a row, or once and then miles later do it again. This is driving my crazy and help would be great.
why not just unplug the bloody thing? Likely throws your O2 sensor readings all to hell...thus the CEL and subsequent lack of lambda input.
I have unplugged it and it still happens. I'm just looking for clues why it is turning on at full temp and if that relates to my problem. I have since last night found the conditions that must exist for it to turn on. I thought I was onto something with the coolant temp sensor being out of spec. I put a new one in and the car ran great last night but today started doing it again. I ohm tested the "new" sensor and it also gave me a weird reading. One set of [email protected] and the other @325ohms. Should be the same right. So I believe this one is faulty and have a new one tomarrow. The other possibility is the CIS-controll unit is bad but I'm not ready to rule that totally in yet, not untill I get a proper reading temp sensor in the motor.
yes, they should agree b/w each set.. who makes the new sensor?
I'd also wonder if your KE unit is freaking out... if you have anyone around w/ any year 560 or even a 420 you can swap KE's easy enough for testing.
jono
Hi jono, I wondered about my KE-unit also. Is there a ohm test or volt test I can do to see if it is in spec. I don't have any friends with parts I could try out.
there are some tests, but nothing spectacular that I've found for pin to pin'ing a KE.. I've always got a stack of spares on the shelf...sooo... You have any bone yards out by you? Ya'll get a LOT of late model 126's out there, I bet you could find a V8 KE for pretty cheap..prolly pick up a bunch of other spare bits while you are @ it..;-)
We do have a Large # of west coast members here, perhaps one lives close by..??
jono
