1988 560 SEC, 2007 CLK350, 1967 Porsche 911S, 1967 Pontiac Firebird 400, 1968 Pontiac GTO Convert.
Ongoing $600 saga of trying to save a 125K-mile SEC with mild rust and scads of other issues. Car sat outside in Royal Oak, MI for glob knows how many years. The rodent damage is actually not that bad, other than the smell. I've done all new brake/fuel lines, just waiting for new rear hoses and clips to finish the job. While it's in the air I started to poke around some other issues:
1. Passenger seat inop. Cleaned the mouse crap out from under the seat and noticed the power connector was disconnected. Plugged it in and the seat immediately moved all the way to the rear and stuck there. Moving the door switch forward just makes a click. Everything else works. Checked the door switch and wiring to the control unit, ok. Memory buttons don't do anything. Getting the seat out is gonna be a b*tch. Looking at the schematic, I should be able to put +12 to the forward/back motor and get at the rear bolts. Will I be able to access the motor plug at the controller from the front? Any ideas on what would make the controller/motor do this? If I leave the power connector plugged in, it makes a clunk now and again like it's trying to go back farther. Looking at the schematic, there's not much that can go wrong other than the controller.
2. Fuses. Aluminum on copper. Cleaned them all, expected things to start working. The antenna just made a grinding noise and I do have puddle lights again. Still no seat belt extenders. Priorities, I guess. Where can I get a set of copper fuses? I'm not paying $3.50 for aluminum from autozone.
3. Aux fan is hard to turn (fuse blown). Read the service manual entry. Got the top two bolts loose under the rad support. Can't seem to get access underneath (the rear is jacked up). Screw it for now. I'm pretty sure the stupid A/C is never gonna work anyways.
4. I've seen posts that mention fuses in the trunk. Is this applicable to the SEC? I'm only seeing an access panel for the antenna and the central lock pump is in the spare tire well, right? It's a swamp back there. Pulled everything out and left it open to dry out for a while. No rust back there yet, except for under the rear window area.
Enough for today. I get kinda down on the car when I start quantifying the negatives.
