My rear bench wont recline. I can hear a click coming from the relay (behind drivers side rear back rest) when I toggle the reclining switch. Also the driver rear heat warmer doesnt work even though it shows one red light (low) when you turn the ignition on, and two lights (high) when you turn the ignition and lights on. The red heat light(s) wont turn off at that point. The passenger rear heat warmer, courtesy light, cig lighter works fine. The only other unusual thing is that my rear driver door panel is off (courtesy light and cig lighter unplugged). I temporarily plugged both of these in while holding the panel, but it didnt make a difference. I also tried known working spare drivers side rear heat and reclining switches from my 91 sel parts car. I havent tried a spare working passenger side reclining switch. Thanks for any suggestions.
