My 1988 190e 2.3 sedan died while stopped at a stop sign and now the starter just makes a whirring sound as if it is turning, but the engine doesn't seem to be turning over. It seems as if the starter isn't engaging the flywheel, or my worse fear is the timing chain has failed. (If so, hopefully there was no damage to valves or cam since it was idling.)<br> <br> Once or twice while trying to re-start it, it seemed as if the engine was about to turn over just as I was releasing the ignition key to try it again.<br> <br> It's an automatic, so I can't push the car in gear to see if there's any compression or to force the engine to turn over. Any suggestions on simple test of starter or timing chain problem?<br> thx,<br> marty
