1 - 1 of 1 Posts
Hi folks, I have a huge trouble, I noticed my car not running smooth in idle, and is throwing a lot of oil from the intake, I thought that could be the injector #2 because the engine did not change when I loose the injector #2. After removing it I found a lot of oil. I replaced the injector and started the car, is still running rough also is blowing air when I remove the valve cover cap and throws oil from there too.
Don't know if could be a valve of piston rings.
Anyone knows where should I start to find the problem???
Thanks.
1 - 1 of 1 Posts
