1982 Mercedes 280SE Euro 1986 420SEL (Project) 1984 300SD 100K
Hey guys i'm looking at a 300D that has an engine knock. The guy said it made a funny noise and then he pulled over and cut it off. Now it wont restart. Any idea?
Discussion Starter #2
Edit: I went and looked at the car and its turning over correctly just dosnt seem to be firing. Any ideas?
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Not really a lot of info here, but it could be fuel-related, e.g. someone inadvertently dumped gasoline in there, or there's some water in the tank; or it could be an oil starvation issue, as in a rod bearing is going; or it could be a timing chain stretched too far. We need more info to help you make a proper determination.
E320 Bluetec S420
The 3.0L OM603 dont have rod bending problems but head crack dose you car temp stays at 90*C or above, Look at STOP lever at the injector pump, when your ignition is at 2nd position dose it go up or dose it stay down, if its stay's down it's cutting out the fuel supply....
