1 - 10 of 10 Posts
son left the trunk open for several days.......battery ran down to 8vdc.....got new battery and hooked it up....when ignition turned, all gauges work....but ignition does nothing. new to these benz, is there a reset somewhere ? any ideas would be greatly appreciated
SuperModerator
1986/1990 W126
Welcome to the forum. Which SDL is it? Not that it matters, I was just going to ask if it's in gear, or if selecting other gears or jiggling the lever will get it being able to start?
Would be great if you could fill out your profile when you get time.
Outstanding Contributor
'17 GLS450, '14 GLK250 "Grandpa's Roadster" Project Car, 350SDL (Sold)
What exactly does "ignition does nothing" mean? (Diesels don't have ignition.)
Do you mean the starter motor doesn't come on? Or do you mean the engine cranks but doesn't fire? If it doesn't crank, try wiggling the shifter or starting in neutral. (It's not in gear, is it?)
engine does not crank.......turn the key gauges work but starter motor does not engage
W124 E260 auto
My 2 cents. Is the car in park? My sister often calls me saying she's stuck. Car won't start because it's in drive.
Are you sure the new battery is fully charged?
Discussion Starter · #7 ·
i shifted thru the range and made sure it wasin park....no change
positive....thanks
Discussion Starter · #8 ·
cycled it thru the gears and is definately in park....no change
Discussion Starter · #9 ·
have disconnected the battery, and gonna wait a day or 2 to reconnect...see what happens
also the battery was fully charged, but trickling it while disconnected just to be positive....thanks
There is nothing to reset. I think you must be overlooking something. My first guess is you haven't gotten good contact with the battery cables. Do you have the factory (or any other) alarm? Does the starter make any noise? Clicking? I'm not sure, but, if you put on the parking or headlights, what happens when you try to start the car?
Get a test light and probe the solenoid wire on the starter. Does it light when you move the key to "start"? Are the connections to the starter clean and tight?
1 - 10 of 10 Posts
