1986 300E Power Flush????
754 Views 3 Replies 2 Participants Last post by  coldfoil
I have a 1986 300E 137K miles. What is the correct ATF fluid for this? ATF III, Dextron, Mercon??? Also, will it damage the transmission if I have it power flushed?
· W124 Moderator
86 190E 2.3L 16V, 95 320TE 02 S500
Dextron/Mercon III is the fluid. Just drain the transmission and torque converter, put in a new filter and forget about "power flushing". I learn something new every day and have now owned 60 cars. Power Flushing the transmission hasn't ever come across the table.
Good Luck
Jayare
Mercedes 1986 300E 165,000 miles
Thanks...I did just that and used Dexron/Mercon high mileage....I did a search on numerous forums and they all said use ATF IIE, ATF IID, Dexron/Mercon....it was all confusing. I did a normal flush but did not drain the TC. Now my problem is that the car is not upshifting until very high RPM (6 - 6.5) and I don't think it is shifting to 4th gear. I adjusted the valve (1 full revolution CW) and is still doing it. This started after I stepped on the gas pedal all the way 5 times (car off, ignition off). I read somewhere that this procedure was supposed to reboot the transmission. I checked the cable and vaccum lines and both are fine.
I resolved my problem by doing a search on the forum. It was simply the KICKDOWN SWITCH behind the gas pedal. It was stuck down and all I had to do was pull it up and it resolved all my transmission problems!
