Hi! I've got an older 190E, that while it runs great, the fuel/air ratio is off enough that my state won't let it pass the emissions test. It's idling in park at slightly above 1000rpms
I've replaced the ignition coil, distributor, cap and rotor, spark plug wires/plugs themselves, the 02 sensor, and I've tried to manually adjust it with the hex wrench method (note that the previous owner had changed it, I assume increasing the fuel), yet when it got down 700ish rpms, the car stuttered and tried to die, so that rules out that method for now. While in park the economy gauge is about 4/5ths of the way up.
Two other things that may be useful information is that I've got the magnetic fan and the auxiliary fan hooked up to manual switches on the dashboard, and there is one sensor I am unsure of what it does/what wire goes to it (I believe it is the water temperature sensor, not sure though, I've attached a picture of not my car, but another 190E, same sensor though), The wiring was mostly ripped out when I got the car and I've been slowly figuring it out. As the wires that are currently in the car, don't match any diagrams I've found, I'm a little nervous about just randomly attaching wires.
Sorry if there was an overload of text, but I'd be really appreciative for any help you folks could offer.
