1986 190E 2.3-16.
156,100 miles
Car is in St. Joseph, MI.
Bought in September 2002 in Traverse City, Michigan from I believe the second owner. Was told it was always garaged. 106,000 miles
Thermostate in 2003
New rear muffler in 2003
Rear sear reupholstered in 2003
In 2004 went from car #1 to #2 and since then has only been driven occasionally. Probably has seen only 6000 miles since 2004.
New Interstate Battery, new mid muffler and catalytic converter - September 2010.
If I was keeping it, I'd be pursuing the following maintanence.
Check pads and rotors
Replace intenna. (motor out, not going down)
Check timing chain and tensioner
Remove rust around wheel well fairings and paint
Replace hood insulation
Replace driver door check
Replace dash panel (around HZAC)
Check turn signal relay (works most of the time - not all the time)
Fix auto door lock (pneumatic leak. the pneumatic pump is still pulling strong)
Replace shift knob (leather cover worn)
Fix driver side heated seat
Thorough engine check/work (156,000 miles without any significant problems yet)
No motor problems
No transimision problems
$3500
email - [email protected]
64 220SE coupe, 69 280SE coupe, 76 350SLC 4-sp, 79 450SLC euro, 83 500SL, 92 500E
Interior pics. Transmission? records please?
Thanks,
Sold
New owner says he has and EVO II body kit to install and an AMG motor. He's going to tear out the interior, add roll cage and start racing it. I understand it's already in the shop.
A good way for this car to finish it's days....
Sold
oh man the car look so clean and original :surrender:
Sold
Why would you put a body kit on a race car??? :cool:
'87 190E 2.3-16
In this case, in order to be able to fit proper track tires. And to improve high-speed stability. The Evo I and II kits were actually functional.
