1 - 9 of 9 Posts
1984 300D
Recently purchased 1985 300D and everything seems to be working pretty well except not too sure about climate control. If you switch unit from OFF to "E" position, fan will not start. All other modes seem to work fine and fan runs in HI/LOW and cycles up and down correctly in Auto. If the fan is already running in another mode except "E", if you then switch it to "E" it runs OK (HI/LOW/Auto) I have ordered but am still waiting for my service manual from MB. The owners manual describes the system but not in the greatest detail. It seems that the fan should work in the "E" mode anytime, Is that correct? If my system has an issue, what component should I be looking for? (bad switch, etc?)
Thanks, Steve
1985 California 300 D Turbo Diesel and '85 Federal 300D Turbo Diesel. '84 Cali 300D - SOLD
Sorry, I don't know how these are supposed to work either. I was wondering what part of VA you're in.
On earlier models, there isn't an "E" button, but we have an "EC" button and the fan should work with that button pressed first.
1984 300D
Fairfax VA. It's really the "EC" button not "E" like I earlier thought. I did read somewhere a detailed description of what vents are supposed to be in operation depending on mode but it did not discuss blower speeds, etc.
1984 300D
Discussion Starter · #5 ·
You are right, it is the "EC" button. Not sure why blower does not come on unless I cycle through another mode first. Perhaps mode switches dirty? Car has about 174K well maintained and super clean interior.
It's possibly the unit itself suffering cold solder joints, it won't get better, but if it doesn't worse and you can live with it, no need to do anything.
1984 300D
Discussion Starter · #8 ·
Good point on the Cold Solder Joint. The old Becker Radio had one. I was able to isolate and repair it, but I got lucky because it was staring right at me when I removed the cover. I'll probably let the Climate control Be unless it gets worse. Steve
1984 300D
Discussion Starter · #9 ·
If you can make it work by cycling and the problem doesn't get worse, leave it alone (especially if you have to pay someone else to fix it).
Hemersam
I'll leave it as suggested unless it gets worse. The car is in really nice shape and the previous owner maintained it well and included all records including original invoice. If it quits or gets worse, I'll probably order a reman switch assy and install it/Steve
1 - 9 of 9 Posts
