I have a 1984 280CE and I would like to know is there an adjustment for removing some of the play from the sterring. If so can anyone explain where the adjustment would be on the box.
Discussion Starter #2
: I have a 1984 280CE and I would like to know is there an adjustment for removing some of the play from the sterring. If so can anyone explain where the adjustment would be on the box. <p>On my former '78 280CE the adjustment was right at the top of the steering box, an set screw with a lock nut. Difficult but not impossible to get at. Turning the screw out reduces play. Go slow, if you go too far the steering will bind. You won't like that and it will wear quickly.<br>
