I have a bad leak on my 300td. I was wondering what the normal causes were. Not sure if it is just a pan gasket or where exactly it is coming from but pretty steady leak. I think my normal procedure would be dis motor mounts jack up engine loosen the pan and do rtv fix to avoid pulling the pan all the way out. Not sure about these engines as far as fixes for this.
