1 - 9 of 9 Posts
1984 300D TurboDiesel
tl;dr skip to paragraph 3.
This story begins about two years ago. I was going through a rough time in my life. I was recently separated with my ex-wife and was in the process of a Med Board in the Navy. My ex took one vehicle when she left, and with child support I couldn't afford the other vehicle that I was left with, so I was going to let it go back so I needed to get something cheap and reliable. A dealer in New Orleans had a 1984 300D advertised on craigslist for $1000. I go there and check it out, and instantly fall in love with it. It had no A/C, windows didn't work (but the sunroof did), and 261,000 miles on the odometer (which didn't work at that time either). I talk him down to $650 and voila, I have my first W123. Took it home and cleaned the window switches to get the front windows working.
Fast forward just over 2 years during which I have only had to replace the alternator, muffler (fell off while driving), and a pull-a-part brake caliper (from slamming the brakes to avoid getting sideswiped too hard). Its high time for me to start building back my credit, and I decided to do so by purchasing a used car, which I did so yesterday. I am still in love with the benz and I didn't trade it in on the new(er) car in hopes of restoring it.
Today I began with the part of the car that has been bothering me the most, which is the floorboard on the driver's side of the car. Here is what I uncovered:
Imgur album link.
(Just doing Imgur albums for now, don't have time to fool with uploading and linking pics at the moment, will be edited later)
So I guess at this point looking for any advice I can get on this project. I have found a 1981 300D at a u-pull-it yard here, the body is in excellent shape so I can cut out body panels from it, though the floor pan is in worse shape than mine.
1985 300D Turbo
You might also want to track down why the rust got to that spot. A common spot are clogged air vents and the pivot point when you open the hood. Sounds like a stretch but this was the case with mine. Good luck!
1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
Most likely that got rusted because water got in through the bad weather stripping, or there was a scrape on the undercoating and salt and water were constantly splashed under the car, as it was up north for a long time.
I haven't welded before, but I'm practicing prior to actually welding in on the car.
My first weld
Rough start, but with a little practice I think I'll be fine.
The more common leak points are as fezcabdriver said => those hinge poket areas and the windshield rubbers. Sometimes a sunroof can be a leak point too.
I would definitely say that the windshield is a leak point now, I noticed it a few days ago while driving. Luckily I have never seen the sunroof leaking, and no rust around it.
Although I am still working on cleaning the rust down to metal and removing the undercoat to see what I'm really working with, I like to look to the future...
What would you guys recommend as the best welding method for this? Keep in mind I will also have to go into the hollow for the repair. Also I'd prefer to use the same for the body when I get to it. My options at this point are arc, MIG, flux core wirefeed, or gas. A TIG setup is a bit more than I would prefer to invest at this point.
I should probably mention as well that 99% of all the work I am going to do will be done outside, as I am having issues convincing the roommate to clear out the garage (not a single thing in there is mine :( )
Just my luck though I decide to start this project and a hurricane comes barreling along.
1985 300D Gone 1985 230CE Perfect, 1984 300TD Driver, 1981 300TD Bad engine
Where the water that caused the rust came from is a moot point as the car is scrap.
With the greatest respect I think you need to practice a lot with what ever you've got first. My advice is not to buy anything until you've got some experience from which you can make your own decision.
1 - 9 of 9 Posts
