Hello All,<br> <br> I'm trying to remove the transmission on a 84' 190D 2.2. I've unbolted everything (as far as I can tell) and am unable to get the transmission to drop. I've taken out the 6 bolts that run through the flywheel and into the torque converter. <br> <br> It seems that the torque converter which is still up against the engine will not allow the transmission to drop. How can I get the torque converter to move away from the flywheel and towards the back of the car together with the transmission? <br> <br> Any suggestion on how I might get that torque converter to move away from the fly wheel? I'm not able to find any place to pry it off. Thanks in advance.<br> <br> Best,<br> T.S.
