Some functions inside the cap are not understood because of the German language written.
1. whenever I stopped pressing the accelarator the engine will quickly stop working and even gear changer is in Empty position or (N).
2. near hand brake there botton which is lifted up or pressed down which is written Start Pilote so whats that resposible for?
Unimog Moderator
250GD Wolf
1. Have you checked position of the hand throttle? It needs to be down a bit to keep the engine running, also check the tightness of it, they can get loose over time or stiff.
2.Start Pilote is an ether injector, meant for cold winter starting. See here for more info: Start Pilot
2617109
1991 U1550L37, 2019 G550
Or is your omg ex military then you’ll not have a handthrottle but instead adjust your idle RPM by turning the know that you push down to cut the engine.
