2009 Mercedes Benz ml320 diesel
I have just purchased this car, and i am restoring it but the problem is the trunk wont open, when i put the key in, the key turns fine but when i pull on the trunk, it doesnt move! Dont know if im doing something wrong.:confused:
First off, this would be a 126 chassis, secondly, if you unlock the doors,(by simply unlocking the driver's door, then all should follow,) and then just push on the lock cylinder, you should be able to open it then. If not, you will need to find the tutorial for drilling it or enlist the help of a locksmith. I had trouble with mine when I first got it too.
