I have a 1983 300d. Its a four spead automatic. It goes smoothly into reverse and shifts smoothly from first to second gear but refuses to go into third. I've tried shifting it manually from l to s to d at 3000rpm and also disconnecting the down shift swich behind the accelerter peddle. I got some advise to check a piston on the side of the transmission to see if it was broken or not applying. How can I test that? And what else should I check? Please help
1978 mercedes 300D "silver streak" 2000 Mercedes ML320 1994 W124 Mercedes e500
I'm not absolutely sure that this is it but just search for B2 piston repair and you should find it
