On my 300d the kickdown switch has always worked fine...until a couple of days ago.
It will kickdown from 2nd to 1st no problem. Withe the key on and pressing the kickdown switch I can hear the solenoid click. So the switch seems to be working ok.
The problem is that I cannot get it to kickdown from 3rd to 2nd anymore or from 4th to 3rd.
As I said it has always worked just fine in the past.
Any ideas?
Has anyone else experienced this?
´85 300D Estate, Unimog 411
Any ideas?
Like some info too...
83 300d (broonhilda), 81 240d (clunky), 90 lexus LS400 (lexy)
I am also having a kickdown issue. Mine wont kickdown at all unless im going over 45mph. are you supposed to hear a click when you hold the switch down and turn the car to on?
Well it seems to work just fine at lower speeds/gears.
I live in the mountains and rely on it quite a bit. I'm very used to how it normally works.
As I said the solenoid clicks when i have the key on and hit the button. It just doesnt work when I'm going I'd say 45 mph and over anymore. It used to be that if i were doing 45 or so that I could kick down and get up to 55-60. Now it does not work at that speed.
Is there an adjustment I can make?
