I did my search on this subject and got very little but nothing is close to my problem. I found similar problems on the M117 450Sl's
I have an 82 380SL which have been parked for most of the winter. It started and idled okay. When I tried to accelerate from a dead stop the engine sputtered and stalled. Once this happened the engine is hard to restart. It took 3-4 cranks to get started again. This happened about two blocks from my house so when I got the engine running again I just let it idles in Drive back to the house. I have a spare WUR and changed it out and the same problem persisted. It has been a while since I changed the fuel filter. Could a clog fuel filter contribute to this problem? Are there any other problem areas I should look into? Thanks in advance and appreciation for any inputs.
