hey guys,
bought a 1981 280se the other week..
hadn't been started in a while.. so the problems i've had so far are
-After it started it revved up to 5-6k revs.. and stayed there..
-Fuel pump wire insulation had burnt and wasn't working, so rewired, and put a switch on the dash..
can anyone please shed some light on why its revving so damn high on startup?
cheers jake
hey guys,
cheers jake
If the engine revs that high, it means a large volume of air is getting in - and more importantly, the car is adding the fuel for it. Is your throttle stuck open?
How long does it stay at 5-6k? And more importantly, how long are you letting it stay there!? High revs on a cold engine is a great way to do massive mechanical damage to all the components in an engine.
the throttle is closed, when i take a peek through that vacuum plate..
i resealed the gasket between the injector pump and throttle plate just incase it was that.. i also couldnt find any major leaks anywhere
is there any common spots i should be looking around?
Well, my knowledge runs out here. If the throttle isn't stuck open, then I have no idea. Something is drawing air in, and the engine is metering out fuel for it.
it was the throttle plate! it was open a tad, so i re-adjusted the little thread type linkage.. and its shut..
now just gotta find a way to fix the metal injector lines haha :S
Huzzah!
